945 D24TIC crankcase -SOLVED
Torbik |
Publicerat 09-10-2016 11:51
Junior Medlem
Registrerad: 27.09.16
Hello again! Sorry for not putting this in the English section.
Could anyone show with pictuses or with a diagramm, where ise the plug for the crankcase located for letting oil out when exchanging oil?
It is not on the bottom like in the gasoline models.
oktober 09 2016 12:25:45:
This is the bolt in the back of the crankcase
could it be the bleed nut?
What bolt is this in front of the engine?
Also can anyone identify these parts, from a oil filter maybe? [/URL]
Redigerat av Sladdaren den 11-10-2016 13:04
Dela den här posten: |
Sladdaren |
Publicerat 09-10-2016 13:05
Sorry my english is sometime a bit rusty . Are you going to change the oil in the engine ?
Torbik |
Publicerat 09-10-2016 13:18
Junior Medlem
Yes.
I will answer my own question: the spring and the other part are from the oil pump. and the bolt in the front of the engine is also from the oil pump. http://www.volvopartswebstore.com/showAssembly.aspx?ukey_assembly=244714&ukey_make=865&ukey_model=20455&modelYear=1992&ukey_category=7866&ukey_driveLine=11320 Parts 8,7,6.
I accidentaly disconnected them and now as I put them back my oil pressure light has come on. Any ideas?
oktober 09 2016 13:20:50:
But still what bolt could be the one in the first picture?
Redigerat av Torbik den 09-10-2016 13:20
Sladdaren |
Publicerat 09-10-2016 13:29
To change the oil in your engine you should have a drain plug on the bottom of the engine. You can watch this guide and you see where the drain plug is.
Your other question about the oil pump i need to research what could have happend
Torbik |
Publicerat 09-10-2016 14:33
Junior Medlem
In my car the original drain plug has been replaced with the one on the first picture .
Is it a allen/hexagon or a special head? |
Sladdaren |
Publicerat 09-10-2016 14:39
ok they change the original plug.
The original looks like this and is a 25mm.
oktober 09 2016 14:54:35:
Yes.
The oilpump problem i dont really know what happend when you install the parts. I found some information on what could go wrong when reinstall the parts.
If you go to this link http://www.nuceng.ca/bill/volvo/Volvo...issing.pdf
And scroll down a few pages you have a few headlines to choose from. Go to Engine: Lubrication and there you have some information what maby got wrong. It starts with Oil Delivery Tube O-Ring Modification Is this guides they have lost the pictures . But hopefully it could help you anyway.
Redigerat av Sladdaren den 09-10-2016 14:56
Fantomvolvo |
Publicerat 11-10-2016 01:24
Senior Medlem
Registrerad: 12.05.15
I recognize this plug from another car, if you are lucky, the shaft of a socket wrench set my work.
Good Luck.
Torbik |
Publicerat 11-10-2016 08:40
Junior Medlem
8mm hexagon fitted. All is well now.
Thanks |
Sladdaren |
Publicerat 11-10-2016 12:45
How did it go with that oilpump parts? . Did you fix that to?
Torbik |
Publicerat 11-10-2016 12:53
Junior Medlem
Yes, disconnected it again and put back together.
The spring was badly insidr the first time probably.
This thread was solved
Thread locked
Redigerat av Sladdaren den 11-10-2016 13:06
