December 17 2025 01:47:18
Var handlar du bildelar?
Biltema
Biltema
5% [1 Rösta]
Mekonomen
Mekonomen
10% [2 Röster]
AD Bildelar
AD Bildelar
10% [2 Röster]
Skruvat
Skruvat
5% [1 Rösta]
Autodoc
Autodoc
10% [2 Röster]
Mekster
Mekster
10% [2 Röster]
Annat / blandat
Annat / blandat
50% [10 Röster]
Röster: 20
Påbörjad: 21.04.25
· koppling och elschem... 15370
· Felkoder Volvo 740 14027
· Luftmassemätare 8463
· Komplett felsökning... 8311
· Rengöring av spjäl... 8017
· Felsökning av gener... 7185
· Byte av mittenbälte... 6604
· Trådar, poster, Vol... 56519
· Nollställa service ... 27777
· Alla åtdragningsmom... 27177
· NY GUIDE Omklädsel ... 22380
· Så här byter du va... 19333
· Besök Volvoswedens ... 18519
· Byta kamrem på volv... 18252
· Lösning på Felkod ... 18094
· Felkoder Volvo 940 h... 17356
· Volvo 740 och 940 by... 16591
Tråd ID: 1453
Det är 2 svar i den här tråden, och den har visats 20567 gånger.
How to unlock your Ford radio 6000 CD and more
How to unlock your Ford radio after a power cut or battery replacement. I Know this is not a Volvo guide but its a lot of Ford users that will be happy for this information in english. If you like to see this guide in swedish language you find it on this link http://www.volvosweden.se/articles.ph...cle_id=534
Have you had a power outage or had to disconnect the battery in your Ford so that you have to re-enter your code into the radio?
If you don't know where you have the code for your radio, you will find out in this guide. Here's how to find out which radio code you have on your Ford!
This guide applies to radio models 6000 CD, 4500 RDS E-O-N, 4000RDS, 5000RDS E-O-N or Sony which are installed in Ford, Fiesta, Focus, Transit, Connect, Fiesta, Fusion, C-Max, Mondeo, Mk, mk2, mk3, mk4, mk5 , mk6.
Here's how to find out which code you have for the Radio model Ford 6000 CD.
1. The radio code is calculated using the radio's serial number.
2. To see the radio's serial number, you need to hold down buttons 1 and 6 for 3 seconds. The radio should now display mixed information including the serial number.
The serial number in the display always starts with a V + 6 digits. Example of a serial number is V070950.
dl.dropboxusercontent.com/s/694e87zenvh8jc1/Hur_man_hittar_koden_till_Ford_fiesta_radion_6000_CD-FORD-Focus-Transit-Connect-Fiesta-Fusion-CMax-Mondeo-Mk-mk2-mk3-mk4-mk5-mk6-radio-code-removal-tools-keys_picture1.jpg
3. If you cannot find the serial number on the display, you must remove the radio. On one side of the radio is the serial number. To loosen the unit, you need to acquire Ford car radio removal tools.
These keys or tools look like below. It is available on Amazon, among others, to order with article number P-SL-T2 for a small penny.
dl.dropboxusercontent.com/s/sgy84fm7ja1mjlc/Hur_man_hittar_koden_till_Ford_fiesta_radion_6000_CD-FORD-Focus-Transit-Connect-Fiesta-Fusion-CMax-Mondeo-Mk-mk2-mk3-mk4-mk5-mk6-radio-code-removal-tools-keys_picture2.jpg
4. To remove the radio unit from the center console lock, connect them 4 keys as in the picture below.
dl.dropboxusercontent.com/s/zh34vxoda5m37yi/Hur_man_hittar_koden_till_Ford_fiesta_radion_6000_CD-FORD-Focus-Transit-Connect-Fiesta-Fusion-CMax-Mondeo-Mk-mk2-mk3-mk4-mk5-mk6-radio-code-removal-tools-keys_picture3.jpg
5. The radio tool must be connected with the small hook inward as shown in the picture below.
dl.dropboxusercontent.com/s/s3l3tgju1w2k0tr/Hur_man_hittar_koden_till_Ford_fiesta_radion_6000_CD-FORD-Focus-Transit-Connect-Fiesta-Fusion-CMax-Mondeo-Mk-mk2-mk3-mk4-mk5-mk6-radio-code-removal-tools-keys_picture4.jpg
6. Now we have managed to get the entire radio out of the center console.
dl.dropboxusercontent.com/s/dipxo2fbjy66nj2/Hur_man_hittar_koden_till_Ford_fiesta_radion_6000_CD-FORD-Focus-Transit-Connect-Fiesta-Fusion-CMax-Mondeo-Mk-mk2-mk3-mk4-mk5-mk6-radio-code-removal-tools-keys_picture6.jpg
7. The radio removal tools are a bit sensitive to how they are connected. Here is a picture showing what the locking hooks on the stereo or radio look like.
dl.dropboxusercontent.com/s/26za7g4y81ok4eh/Hur_man_hittar_koden_till_Ford_fiesta_radion_6000_CD-FORD-Focus-Transit-Connect-Fiesta-Fusion-CMax-Mondeo-Mk-mk2-mk3-mk4-mk5-mk6-radio-code-removal-tools-keys_picture5.jpg
8. Here on the page you see the radio serial number. Mine started with an M + 6 digits. Example M080890.
dl.dropboxusercontent.com/s/hqy6catvx8h2yho/Hur_man_hittar_koden_till_Ford_fiesta_radion_6000_CD-FORD-Focus-Transit-Connect-Fiesta-Fusion-CMax-Mondeo-Mk-mk2-mk3-mk4-mk5-mk6-radio-code-removal-tools-keys_picture7.jpg
9. Now the last step is to download the Ford radio codes app to your mobile phone. I used Google play because i have an android. You with an iPhone can download this from the App Store.
dl.dropboxusercontent.com/s/1yz049o0nmlqqb9/Hur_man_hittar_koden_till_Ford_fiesta_radion_6000_CD-FORD-Focus-Transit-Connect-Fiesta-Fusion-CMax-Mondeo-Mk-mk2-mk3-mk4-mk5-mk6-radio-code-removal-tools-keys_picture8.jpg
10. Enter your serial number in the app and in no time you will get the correct four-digit code for your Ford radio.
Feel free to write a comment. Good luck.
For the radio model 4500 RDS E-O-N you only need to hold button 2+6 and the serial number should be showing in the display. Example on serial number for this radio you can see on the picture.
dl.dropboxusercontent.com/s/hygw1ul000e33tg/4500-RDS-E-O-N.jpg
When you know your serial number for your radio you need to download the Ford Radio code app. Just visit Google play for Android or App Store for Iphone. Start the app and write the serial number and you get your 4 digit code. Smile
For the 4000 RDS and 5000 RDS E-O-N unit you need to remove the whole radio out of the center console. This model doesn't have the option to show the serial on the screen. You do not have to use any special tools to get the radio out. Here you can watch a short video how to unlock the radio for the center console with only 2 screwdrivers https://youtu.be/KCMd-MDZcTM. The serial number should be written on the side sticker and starts with a M+6 digits.
dl.dropboxusercontent.com/s/4474kccmxdagosg/Ford_radio_4000-RDS_unlock_serial.jpg
And for the Ford Sony radio there are two different units that depends on model year. The early units from year 2004 to 2007 you can watch the beginning of this guide. Its the exactly the same as Ford 6000 CD. You need to remove the whole radio unit from the center console. And there is the flat tool keys you need. The serial number should be found on a sticker on the side when you manage to remove the whole unit. After you locate your serial number you need to download the Ford Radio code app.
dl.dropboxusercontent.com/s/4nnp0f29hy0n4e4/Ford_sony_radio_code_unlock_keycode.jpg
An the final Ford Sony radio unit is for the model years 2008 to 2015.
1. Press and hold buttons 1 and 6 for several seconds to enter in service mode, time in which different info displays for 30 seconds.
2. The serial number is displayed next to last, should look like this format: SOCD1XBV123456
3. Download the app Ford Radio code on Google play or app store.
Redigerat av Sladdaren den 02-01-2023 23:40
Farsans Ford Fiesta 2006 - Såld Projekt 10 18-09-2023 09:27
S80 ´05 HU-850 6CD original radio Billjud Belysning Multimedia Elektronik 3 16-09-2019 12:59
Ford Mondeo 2.0 -97 oljebyte Projekt 58 14-08-2019 18:23
Polis radio DSL-160 Billjud Belysning Multimedia Elektronik 1 03-02-2019 12:17
Alla bil manualer Volvo, Ford, Mazda etc Allmänt bil och motor 1 06-02-2018 15:42
262 Användare (3.47%)
16-12-2025 23:14
n.se/forum/viewthr
e...ad_id=1602
07-12-2025 10:05
OOPS
02-12-2025 20:28
n.se/forum/view...
post_11121
29-11-2025 21:26
18-11-2025 20:28
17-11-2025 00:14
15-11-2025 18:16
Tror jag blev med 245a igen
· Registrerade användare: 7,574
· Senast registrerade användare: Sickelsjojacob
87,602,491 unika besök
