November 04 2026 18:17:15
· Felkoder Volvo 740 15403
· Trådar, poster, Vol... 58836
· Nollställa service ... 36155
· Alla åtdragningsmom... 31383
· Felkoder Volvo 940 h... 29932
· NY GUIDE Omklädsel ... 24905
· Felkoder Volvo 740 h... 23293
· Så här byter du va... 21895
· Besök Volvoswedens ... 21015
· Lösning på Felkod ... 20934
· Byta kamrem på volv... 20293
Tråd skapare: Torbik
Tråd ID: 903
1992 940 window problems -Solved
Torbik
Hello once again!
I have a problem with my driver side electrical window. The mechanism works good and everything but i really cant move the window down, as the glass starts to tilt to the front when I move it. The window moved perfectly well before, this problem just happenedi1307.photobucket.com/albums/s596/Nurmkana/20170401_175821_zpsebpmwohh.jpg
I opened it up and I didn't feel anything that would be in the way of the glass when moving it down, but what I did see was that when I move the glass down, it comes out of the rail it moves on( the first picture is from the back side and then moving to the front). i1307.photobucket.com/albums/s596/Nurmkana/20170401_175353_zpssbp5rdzh.jpg
i1307.photobucket.com/albums/s596/Nurmkana/20170401_175358_zpsqbhc9oph.jpg
i1307.photobucket.com/albums/s596/Nurmkana/20170401_175402_zpshxgykqo8.jpg
So I thought, that should the glass be glued on the rails?(have not heard about that before)
Any solutions?
Cheers
Redigerat av Sladdaren den 04-04-2017 22:12
The window should have a spline on the bottom with holes. And sometimes the lock clips pops out.
volvosweden.se/images/Volvo_guider_manualer/Guider/Elhissar%20montering%20och%20koppling/SAM_6173.JPG
On the video you can see the lock clips that holdes the window in place.
Torbik
Talked to a guy who has been working on volvos for a long time.
He told me that the 700 has a different type of glass, and that the 900 has two types of glass. One that is glued to the rails and one that connects just like the 700 type, but there are small differences.
Just thought i should share this info.
Ty for info Cool
Torbik
I glued the glass back on the lifter and also the rear glass guide/rails were broken, replaced them.
Problem solved
Nice. Thread locked, problem solved
Redigerat av Sladdaren den 04-04-2017 22:11
Volvo 945 turbo 1992 Såld Projekt 6 10-06-2018 10:53
· Besökare: 26
101,633,168 unika besök
