Maj 26 2024 15:40:13
13% [3 Röster]
26% [6 Röster]
30% [7 Röster]
22% [5 Röster]
Röster: 23
· Felkoder Volvo 740 12933
· koppling och elschem... 12227
· Luftmassemätare 7514
· Komplett felsökning... 6953
· Rengöring av spjäl... 6734
· Volvo 740 armatur sa... 6186
· Felsökning av gener... 6160
· Byte av mittenbälte... 5670
· Byta vattenpump Volv... 5391
· Volvo v70 instruktio... 5343
· TrÃ¥dar, poster, Vol... 43081
· Alla Ã¥tdragningsmom... 19054
· NY GUIDE Omklädsel ... 16069
· SÃ¥ här byter du va... 12882
· Byta kamrem pÃ¥ volv... 12773
· Lösning pÃ¥ Felkod ... 10285
· Besök Volvoswedens ... 10261
· Guide pÃ¥ hur man po... 10034
· Nollställa service ... 9736
· Vill du starta en pr... 9617
Tråd skapare: firstrebel
Tråd ID: 1474
Det är 3 svar i den här tråden, och den har visats 1675 gånger.
P3 V70 door trim
firstrebel
I have a 2009 P3 V70 2.5T. The lower trim on the outside of the drivers door is loose and bangs when going over bumps. I looked at the Volvo diagram and it shows it is held by 6 clips. But it will not come off. Is there something else? I know the P2 had bolts from the inside of the door. I have taken the door card off but cannot see anything obvious.
Thanks
Bob
i.ibb.co/5K9DmZX/door-trim.jpg
i.ibb.co/cQThnbk/lower-door-trim.jpg
www.volvoclub.org.uk
Hi
I am googling on this and find a picture on a door trim from rear left. This picture is from a 2008 year model. I see only clips that is held on this trim I post a link to it https://www.bildelsbasen.se/33-W18090...0907.html#
firstrebel
I found this photo of the back of the trim from a 2010 V70 and it shows only clips. Maybe they are very tight to get off. I will put a piece of double sided tape at the end of the trim and hope that will keep it secure.
[img]i.ibb.co/vZG9Y32/lower-door-trim-rear.jpg[/img]
248 Användare (3.73%)
17-05-2024 08:50
-cgOBWbj4A?si=yOK3
L...yqKUDQrCV_
· Besökare: 18
· Registrerade användare: 6,672
· Senast registrerade användare: erling81
68,164,323 unika besök
