April 25 2024 17:33:30
· TrÃ¥dar, poster, Vol... 42935
· Alla Ã¥tdragningsmom... 18833
· NY GUIDE Omklädsel ... 15895
· SÃ¥ här byter du va... 12700
· Byta kamrem pÃ¥ volv... 12615
· Besök Volvoswedens ... 10060
· Lösning pÃ¥ Felkod ... 9976
· Vill du starta en pr... 9488
· Spola rent kylsystem... 9437
Tråd skapare: sergio001
Tråd ID: 672
Det är 3 svar i den här tråden, och den har visats 44458 gånger.
Problem Bypass air control/Throttle valve control
sergio001
Hello everybody.
I have a Volvo V50, (M/Mw76/V50), 1.6d, 80KW, year 2006, engine D4164T.
I have some problems with the engine.
The faults codes in VIDA are:
ECM - 68BD Intercooler bypass throttle - Faulty signal
ECM - 9150 Inlet control valve - Signal too low
ECM - 6890 Intercooler bypass throttle - Signal too low
ECM - 9120 Inlet control valve - Signal missing
ECM - 688D Intercooler bypass throttle - Signal missing
The full body of this parts -Bypass air control valve + Throttle valve control unit - are new.
First time when the faults codes starts, the Volvo dealer check the wires, ground connections, fuses... and after that recommend to change the whole part.
After they change it, the fault codes come again. They change again the whole part in warranty, but again the same fault codes. At that moment they tell me that they believe is the ECU.
I send the ECU to BBA England to be check and they tell me that the ECU is fine.
Back to Volvo, they says that is the ECU.
Contact again the BBA England, they check again the datas and the ECU is fine.
I buy Power Probe Short Finder ECT2000 and it never show a broken wire.
I make measurements of the voltage/resistance of the wires of the valves and I have this values:
Measurements of voltage:
For the Bypass air control valve -- A14.4
pin #1 - 4.96 V
#2 – no wire
#3 - 3.2 V
#4 - 12.15 V
#5 - 0V
#6 - 0V
For the Throttle valve control unit A20.1
pin #1 - 4.96 V
#2 – no wire
#3 - 12.15 V
#4 - 2.77 V
#5 - 0V
#6 - 0V
Measurements of resistance:
pin #1 - 1 ohm
#2 – no wire
#3 - 1 ohm
#4 - 1 ohm
#5 - 0.7 ohm
#6 - 1 ohm
pin #1 - 1 ohm
#2 – no wire
#3 - 1 ohm
#4 - 1 ohm
#5 - 0.7 ohm
#6 - 1 ohm
The engine is tremble like hell, but not slow /rare, more like shivering. And when it stop/shut off, it doing a post-combustion... is still rotate a few more time and finally stop with a very strong tremor / vibration. The acceleration is slow, it's feeling a lack of power and when I go over 3000-4000 r/min get dark smoke on the pipe.
I was to a garage and try to force the regeneration of the Particle filter but when start to accelerate, the engine start to move as if it had broken tampons/bumpers and the whole car start to tremble so they stop the regeneration.
If anyone has any ideas is more than welcome.
Thank you.
This error you have with The engine is tremble like hell". You dont have this when the car starts cold ?.
On your dashboard - do you have the warning check engine light?.
I was looking if i could find something in the wiring diagram for your modelyear. Maby you can find some information or at least how the color wires go to.
http://volvosweden.se/articles.php?ar...cle_id=158 or this link directly to your year http://www.volvowiringdiagrams.com/vo...iagram.pdf
There is some info at youtube on Bypass air control/Throttle valve control and some of the videos saying that the wiring can be the problem. I dont find any measure numbers for this. But if you find anything please write it here thumpsup.
Hope you understand my rusty english Pfft
Redigerat av Sladdaren den 13-03-2016 21:57
sergio001
Hello.
Do not worry, my english is also not perfect.
Yes, indeed, is it doing like this from the start of the engine, cold or warm, the same. And there are no warning lights on dashboard - no warning Check Engine Light.
Wiring diagram I use this one. .. ,, TP3990202 2006 S40 V40 Wiring Diagram"
On you tube there are a lot of videos but nothing helpful for me until now.
Felkoder & "konstiga" ABS problem V70 2.4 -05 Felsökning Volvo SVXC 850 V70 S80 S60 V50 m.m 6 20-02-2024 14:26
Volvo v70 2,4 problem Felsökning Volvo SVXC 850 V70 S80 S60 V50 m.m 5 15-12-2023 22:44
Volvo 850 -95 larm problem Felsökning Volvo SVXC 850 V70 S80 S60 V50 m.m 3 26-11-2023 14:44
Hjälp en gröngöling med div Volvo 740 problem! Felsökning Volvo 240, 740 och Volvo 940 2 02-10-2023 09:30
AC-problem märkligt Felsökning Volvo SVXC 850 V70 S80 S60 V50 m.m 3 24-06-2022 15:48
· Besökare: 18
66,875,809 unika besök
