April 25 2024 19:10:33
· TrÃ¥dar, poster, Vol... 42935
· Alla Ã¥tdragningsmom... 18834
· NY GUIDE Omklädsel ... 15895
· SÃ¥ här byter du va... 12702
· Byta kamrem pÃ¥ volv... 12616
· Besök Volvoswedens ... 10061
· Lösning pÃ¥ Felkod ... 9977
· Guide pÃ¥ hur man po... 9895
· Vill du starta en pr... 9488
· Spola rent kylsystem... 9437
Tråd skapare: volvo264
Tråd ID: 1173
Det är 21 svar i den här trÃ¥den, och den har visats 45910 gÃ¥nger.  Det finns även bifogade filer.
1977 Volvo 264GL B27E Restoration
volvo264
Greetings from New Zealand all !. I rescued a B27E 1977 Volvo264GL that was in storage for 18 years and in the process of bring it back to close factory condition. I manage to start the car within 3 weeks and decided to restore it. Mechanical its in very good condition and as usual it has surface rust . I an hoping to get advice and assistance from your experiences and hopefully source difficult parts from your region. Some pic and links below
Youtube channel https://www.youtube.com/channel/UCpN_...A/featured
volvo264 bifogade följande bild:fil:
Redigerat av Sladdaren den 02-06-2019 11:54
rgds
Don
https://www.youtube.com/channel/UCpN_g19vFvJQX9WhAbArBrA/featured
264GL B27E 1978 - 2017 Barn-Find
https://www.facebook.com/volvo.ovlov.165
volvo264
More pic of work done so far
rgds
Don
volvo264
Body work cont..
rgds
Don
volvo264
Brakes .. restored and fitted new items where needed
rgds
Don
Hi!
Realy great work you done with the car! Realy nice to see!Holy
A really fun project to see thumpsup. I visited your youtube channel and clicked the subscribe button. I will watch your videos later today. japp
Welcome to Volvosweden Greetings
volvo264
Hi!
Cheers Inthewhite , its a 2 year project and hopefully I will get this painted summer dec 2019 . I have driven it before I started on the interior and suspension work and its not so bad https://youtu.be/-ZtChZHsa8w . Just need time to complete the work .
Is there any good site in Sweden for getting old hubcaps like the pic attached .
rgds
Don
volvo264 skrev:
Hi!
I haven´t seen new ones, but you can try to find used ones here:https://www.facebook.com/groups/72395...oup_header
volvo264
Is there any good site in Sweden for getting old hubcaps like the pic attached .[/quote]
I haven´t seen new ones, but you can try to find used ones here:https://www.facebook.com/groups/72395...oup_header[/quote]
cheers will do . thanks
rgds
Don
volvo264
ThanksGreetings
rgds
Don
Looks pretty nice to drive this Volvo on the roads. thumpsup. It got a bit scary to see someone drive on the left side Grin. I think we here in Sweden switched from Left to right side driving on the 60´s.
Anyway this project is going to be so fun to follow
volvo264
Headlight Frame restoration.
The Headlight frame had some surface rust when removed and did some tidy up. The beam adjust screw was buggered and got new ones but the tab that receives it is loose. I may have to just use cable tie to secure it. Some pic below
rgds
Don
Nice fix japp. Cable ties works for everything..
volvo264
Interior Floor & Boot section
Inspected the interior floor , trunk cleaned where necessary and plan on what is needed . The floor is not rusted but the old 42 year old vibration , sound and carpet insulation layer was crumbling. Also had some coolant leak on the passenger side. Removed all the carpet and tided it up and will put it back it once painting is done. The carpet was faded but not too worn so I will reuse it to keep some period look.. Some pic of what was done.
rgds
Don
It feels realy nice when the interior also is cleen. Smile
volvo264
yes, its like peeling onion hopefully not too much tears at the moment.. more pic
rgds
Don
Pretty impressive when there is no rust thumpsup. Nice to see all the work you do on your car. Keep it up Smile
volvo264
A long over due update cos been busy with something called WORK! and this lockdown meant just doing odd bits and its Winter here now.
-Underbody protection also under the petrol tank
I forgot how to attach pic.. will try again
rgds
Don
volvo264
More update, Rear light reflector and lens and a 3rd brake light
rgds
Don
volvo264
Original Hooters Horn , did some research and its from UK . Came out nice then expected and brass connectors still in good condition after some brushing. Added additional terminals for installing alarm later.
rgds
Don
· Besökare: 21
66,878,754 unika besök
