Mars 28 2024 16:10:03
17% [3 Röster]
28% [5 Röster]
28% [5 Röster]
17% [3 Röster]
Röster: 18
· Koppla och ansluta e... 5
· Felkoder Volvo 740 12925
· Luftmassemätare 7494
· Komplett felsökning... 6929
· Rengöring av spjäl... 6713
· Felsökning av gener... 6146
· TrÃ¥dar, poster, Vol... 42843
· Alla Ã¥tdragningsmom... 18680
· NY GUIDE Omklädsel ... 15768
· SÃ¥ här byter du va... 12563
· Byta kamrem pÃ¥ volv... 12504
· Besök Volvoswedens ... 9911
· Guide pÃ¥ hur man po... 9806
· Vill du starta en pr... 9396
· Spola rent kylsystem... 9354
· Nollställa service ... 8900
Tråd skapare: Torbik
Tråd ID: 1127
Det är 3 svar i den här tråden, och den har visats 10782 gånger.
Volvo 7/940 front springs and shock absorbers
Torbik
Hello!
This is a small guide on how to change your Volvo 7/940 front springs and shock absorbers. I will use older and newer pictures, but the quality isn't good, sorry about that.
EDIT: I reassembled the rubber bushing on the strut plate the wrong way around. It should be orientated like in the first picture but I assembled it the wrong way(look at the last picture). What do the members think, how serious is it?
You will need:
A socket/wrench set (mainly sizes 15,17,18,19)
A 24mm wrench or a adjustable wrench
A Torx T45 wrench
A pair of spring clamps
And other hand tools.
First, jack up the car and block the rear wheels, take off the front tire.
Before you start the work, I would mark the locations of the strut bearing 15mm nuts with a marker to make sure you get the alignment as close to before as possible, but you still might have to get a tire alignment.
farm5.staticflickr.com/4846/45372738005_c78fdb1afa_c.jpg
Next, remove the two 18mm bolts holding the brake caliper assembly in place and put it away, on the wishbone or put a bucket under it.
farm5.staticflickr.com/4905/45373030055_6959cf32c7_c.jpg
farm5.staticflickr.com/4827/46285798221_5827c5c6f1_c.jpg
Remove the 19mm nut holding the steering rod to the knuckle and tap it loose with a hammer (hit the part where the steering rod goes through, blue arrow)
farm5.staticflickr.com/4818/31348034357_817e4c7408_c.jpg
Then remove the two 18mm or 17mm bolts holding the ball joint to the strut.
farm5.staticflickr.com/4897/46285329511_f3559f298c_c.jpg
farm5.staticflickr.com/4820/46285331451_9e006cf14c_c.jpg
Then loosen the 15mm bolt on top of the stabilizer bar, so you could move the wishbone down. If you want to, you can remove the lower 17mm bolt, that connects it to the wishbone.
farm5.staticflickr.com/4880/45374221985_bd8536238c_c.jpg
Now, pry the wishbone down and lift the strut off it.
You can choose to remove the brake disc if you want to, but it didn't bother me.
Loosen the 15mm bolts under the bonnet (first picture). Do not loosen the big 24mm bolt!!!
This should be your reward:
farm5.staticflickr.com/4888/45561733744_7d33a4c66e_c.jpg
Now, put the spring clamps on the springs, lubricate the threads with oil and start to put tension on the spring. Make sure the spring is as straight as possible. If you have compressed the spring enough and you can move it in the strut, take your 24mm wrench and a T45 torx and loosen the upper big bolt. Don't lose the big rubber bushing that goes between the nut and the plate.
When removed, lift the spring out. and release the pressure on the spring evenly (if you only want to change your shock absorbers, leave it like that in a safe space), remove the top rubber part with the bearing from the spring, you should have these removed.
The rubber part with the dust cover:
farm5.staticflickr.com/4886/46285441851_73b4181038_c.jpg
The bearing plate:
As you can see, mine were in pretty bad shape, I could remove the bushing by prying with a screwdriver
farm5.staticflickr.com/4845/32413771418_f71c46b11e_c.jpg
The bearing (this should be "stuck" in the plate):
On the left is the old bearing, remember the orientation of the bearing
farm5.staticflickr.com/4904/46285430051_fb39bf788c_c.jpg
Check if your new bearing has grease in it, never put in bearings dry.
If you want to remove the shock absorber, you have to loosen this big nut, mine were VERY rusted and stuck to place, use heat to warm the metal where the inside threads are, tap it with a hammer where the inside threads are and use a big adjustable wrench or pipe wrench to undo the bolt. Now this can be difficult, as you can not hold it in place. Maybe you can get it to move while it is still in the car by peeling up the dust cover, and going through the spring, but I used this:
Attach a wheel to the bolts and have a heavier friend stand on the wheel while you try to loosen the nut.
farm5.staticflickr.com/4865/31348409657_228d78a98a_c.jpg
Remove the nut, insert a new shock absorber, tighthen the new nut.
Put the new spring in place (it needs to be compressed) then put the dust cover in, attach the rubber to the spring's upper part, and the new bearing with the plate.
tighten the 24mm nut and decomress the spring slowly.
Reward:
farm5.staticflickr.com/4833/45561811894_0819ee8a15_c.jpg
This is also a good time to clean all the surface rust under the strut tower.
farm5.staticflickr.com/4853/32413789808_b2e4c2c2b2_c.jpg
Put the strut back into the car, tighten the two 15mm bolts under the bonnet and reassemble everything.
I hope this guide helps you, but remember to think with your own head! I am not an auto repair technician so there might be some mistakes.
Redigerat av Torbik den 12-12-2018 16:11
A great guide guide as usual Torbik. And very clear and good pictures Holy. I recently did a replacement with that part in this guide with the the ball joint to the strut.. It was so rusted stuck that i had to replace the whole strut. It was so bad sad2 but got it on a video on Youtube.
Torbik
With the car on the ground I loosened the 24mm nut again and turned the bushing the right way.
If I had not made this guide I might have not noticed the problem for some time Grin
Sladdaren - yes it can be rusty, when I changed my shock absorbers, one of the large nuts was so rusted that it broke off. I even tried to weld something to it so I could turn if, but it didnt work and I had to buy a new strut aswell.
Volvo XC90 2,5t AWD 7-sits.. -04 Projekt 35 27-03-2024 19:37
Volvo S70 felkod Felkod P1671 Felsökning Volvo SVXC 850 V70 S80 S60 m.m 13 15-03-2024 10:20
248 Användare (3.79%)
27-02-2024 22:45
20-02-2024 12:22
· Besökare: 18
66,096,434 unika besök
